rtl-server-policy
Creates an RTL
server policy and enters its configuration mode. When configured and
applied on an access point, this policy enables the sending of RSSI feeds
from the access point to a server. The RTL server policy provides the
exact location (URL) of the server. The RSSI feeds sent are as per the
sensor-policy configured and applied on the access point. Therefore,
ensure that a sensor-policy, with the rssi-interval-duration specified, is
existing, configured, and applied on the access points.To initiate RSSI
feed posts to the Euclid locationing server, use the RTL server policy
on the:
- AP‘s device/profile
context, or
- AP‘s RF Domain
context.
- Access Points —
AP410i/e AP460i/e, AP505i, AP510i/e, AP560i/h, AP7602, AP7612, AP7622, AP7632,
AP7662, AP8533
- Service Platforms —
- Virtual Platforms —
CX9000, VX9000
Syntax
rtl-server-policy <RTL-POLICY-NAME>
Parameters
| <RTL-POLICY-NAME> |
Specify the RTL server policy name. If an RTL server
policy with the specified name does not exist, it is created. |
nx9500-6C8809(config)#rtl-server-policy test
nx9500-6C8809(config-rtl-server-policy-test)#?
RTL Server Policy Mode commands:
no Negate a command or set its defaults
url Configure the url to send the real time RSSI feed to
clrscr Clears the display screen
commit Commit all changes made in this session
do Run commands from Exec mode
end End current mode and change to EXEC mode
exit End current mode and down to previous mode
help Description of the interactive help system
revert Revert changes
service Service Commands
show Show running system information
write Write running configuration to memory or terminal
| no |
Removes an existing RTL server policy |
| use (profile/device-config-mode-commands) |
Documents the ‘use‘ command in a device‘s profile or
device configuration context. Use this option to associate this RTL server policy to
an access point‘s profile or device. |
| use (rf-domain-config-mode) |
Documents the ‘use‘ command in the RF Domain
configuration context. Use this option to associate this RTL server policy to an RF
Domain. When associated, the policy is applied to all access points within the RF
Domain. |
